Question about main gate passes
Monorail_Red
Department: Monorails
Position: Former CM
Post by Monorail_Red » Tue Dec 07, 2010 8:03 am
Hey I have a question about the main gate passes and maybe I can get some input.
As many of you probably know, I no longer work for WDW. However I still have a few main gate passes left that I never used.
I even received my holiday pass as well, and for that it says that in place of a company ID, you can use a drivers license. I think that's also true for the main gate passes.
I have heard of CP's using their main gates without a company ID. I have heard of instances where if they stayed a few days after their program end date, they were able to use up their remaining main gate passes without a company ID.
So my question is...will I still be able to use those passes? I'm going to be there this weekend and I have tickets but I figured that it is worth a shot.
Thanks in advance,
Monorail_Red
Regards,
Monorail_Red
The views and opinions expressed on this post are mine and do not necessarily represent or reflect those of The Walt Disney Company.
Re: Question about main gate passes
Post by Big Wallaby » Wed Dec 08, 2010 4:30 am
My guess? They are no longer valid.
Park: WDPR
Department: Industrial Engineeri
Position: Former
Post by kurtisnelson » Wed Dec 08, 2010 9:00 pm
Monorail_Red wrote:As many of you probably know, I no longer work for WDW. However I still have a few main gate passes left that I never used.
Should be valid as long as you left on good terms. How about I see if my maingates work when I attempt to use them later this week?
5th Dimension
Post by 5th Dimension » Thu Dec 09, 2010 12:14 am
The main entrance people at the turn style ask me for my ID if I use my main gate. Is it just for verification? Could you use a driver license instead? Not sure.
Monorail_Red
Position: Former CM
Post by Monorail_Red » Thu Dec 09, 2010 5:49 am
kurtisnelson wrote:Should be valid as long as you left on good terms.
Well I did leave on good terms with an unrestricted rehire status. This might explain why they sent me my holiday pass which was dated after my last day of work...and in the fine print of that, it said that a driver's license is acceptable.
kurtisnelson wrote:How about I see if my maingates work when I attempt to use them later this week?
That's a big 10-4, I'll be in touch.
5th Dimension wrote:The main entrance people at the turn style ask me for my ID if I use my main gate. Is it just for verification? Could you use a driver license instead? Not sure.
They mailed me my 2010 holiday pass which was dated after my last day of work...and in the fine print of that, it said that a driver's license is acceptable. I'm thinking that that's how CPs are able to use their remaining maingates after their program ends and they no longer have their IDs.
Regards,
Monorail_Red
glendalais
Post by glendalais » Thu Dec 09, 2010 6:22 am
Your Main Entrance Pass will not work if you're not a current employee of The Walt Disney Company and Affiliated Companies. Indeed, it's considered Company property and is supposed to be turned in upon termination or seperation from the company. Likewise for your Disney Family Holiday Celebration ticket (it even states so on the back).
If you have Cast Complimentary Tickets, those can continue to be used even after your employment has completed.
Park: WDPR
Position: Former
Post by kurtisnelson » Thu Dec 09, 2010 9:13 am
glendalais wrote:Your Main Entrance Pass will not work if you're not a current employee of The Walt Disney Company and Affiliated Companies. Indeed, it's considered Company property and is supposed to be turned in upon termination or seperation from the company. Likewise for your Disney Family Holiday Celebration ticket (it even states so on the back).
Turnstiles coordinators have told me that drivers license is acceptable if your white ID expired. I wasn't asked for my maingate or anything back, just my ID.
mapo
Post by mapo » Thu Dec 09, 2010 5:09 pm
kurtisnelson wrote:Turnstiles coordinators have told me that drivers license is acceptable if your white ID expired. I wasn't asked for my maingate or anything back, just my ID.
Sounds like something else your managers need to be coached on.
ugh
mapo
Nobleman
Post by Nobleman » Fri Dec 10, 2010 11:55 pm
mapo wrote:Sounds like something else your managers need to be coached on.
ugh
mapo
What? Consistent, accurate knowledge amongst WDW staff?
Monorail_Red
Position: Former CM
Post by Monorail_Red » Mon Dec 13, 2010 1:19 pm
Well I just got back and everything worked!
glendalais wrote: Indeed, it's considered Company property and is supposed to be turned in upon termination or seperation from the company. Likewise for your Disney Family Holiday Celebration ticket (it even states so on the back).
Sort of...but more specifically it says that it needs to be surrendered at termination of employment...
OR
at the request of the company.
They never requested for it back, PLUS they mailed me my holiday celebration pass to me AFTER my last day of work. So I guess Mickey wanted me to play in the parks as I did. :D:
That's what I figured. It must have to do with restricted & unrestricted rehire. I was given an unrestricted rehire status when I left.
Monorail_Red
Regards,
Monorail_Red
