Wierd Disney Parks secrets
at Disneyworld. outside Aladdin's ride, the camel statue can spit water and a CM operates it.
Mr Toads statue that used to be on his ride is now in the haunted mansion pet cemetary.
I forgot what the plack says thou.
Re: Wierd Disney Parks secrets
Found It:
DEAR MR. TOAD
IT'S SAD BUT TRUE
NOT NEARLY AS MARKETABLE
AS WINNIE THE POOH
DEAR MR. TOAD
IT'S SAD BUT TRUE
AS WINNIE THE POOH
Sort of. Cast Members at that attraction can turn the camel on and off, but the exact moments he spits are determined by a timer.drcorey wrote:at Disneyworld. outside Aladdin's ride, the camel statue can spit water and a CM operates it.
This is actually a new statue, not one moved from the former attraction.Mr Toads statue that used to be on his ride is now in the haunted mansion pet cemetary.
weird, everyone said it was a ride building statue repainted.Zazu wrote:Sort of. Cast Members at that attraction can turn the camel on and off, but the exact moments he spits are determined by a timer.drcorey wrote:at Disneyworld. outside Aladdin's ride, the camel statue can spit water and a CM operates it.
Normally Central Shops uses different materials for indoor vs. outdoor construction, as the indoor fixtures don't have to be UV and water resistant. I suppose it's possible they stuck the old statue on a new base and coated both with an exterior treatement that is UV resistant, but that's not their usual approach.drcorey wrote:weird, everyone said it was a ride building statue repainted.Zazu wrote:This is actually a new statue, not one moved from the former attraction.drcorey wrote:Mr Toads statue that used to be on his ride is now in the haunted mansion pet cemetary.
But if you have that data from someone who worked in Shops or Imagineering at the time, I'll bow to that. I'll certainly grant that the figures came from the same mold, as the size and posture are the same.
hmm, I just read it online somewhere.
My understanding is that everything we read on the internet is true.
I read that on the internet somewhere.
Abraham Lincoln said it.YANXWIN wrote:My understanding is that everything we read on the internet is true.
I thought Snopes proved it was Washington spoofing Lincoln?BRWombat wrote:Abraham Lincoln said it.
Near Philly
Lincoln made the mistake of not logging out of his Facebook account.
Washington just took advantage of that opprotunity. Now look what happened.
