Today was the first time I created a post with a link in it. I used the URL button and it gave me begin and end url tags. I put the URL in between and everything seems to work just fine, except...
I always used to change the text of the link to something in English rather than the URL and I wasn't sure if it could be done on the new site. I thought there might be a tag attribute or something to specify text. Can anyone enlighten me?
Qeuestion on embedding a URL
Re: Qeuestion on embedding a URL
Let's test it right here, right now.
Stupid Guest Tricks
Okay, so I am going to replace the brackets with parenthesis, and it looks like this:
(url=http://www.stupidguesttricks.com)Stupid Guest Tricks(/url)
Stupid Guest Tricks
Make sure and use [ instead of (.Big Wallaby wrote:(url=http://www.stupidguesttricks.com)Stupid Guest Tricks(/url)
Yes. Undo what I did to show it. Plus, if you're here linking to the SGT homepage, there is something wrong with you. Just my professional opinion.hobie16 wrote:Make sure and use [ instead of (.
Thanks, BW!
You can use the code button to show code too.
Code: Select all
[url="http://www.stupidguesttricks.com"]SGT[/url]
