Bye-Bye to TRON-o-Rail
- Monorail_Red
- Department: Monorails
- Position: Former CM
It has already been discussed on other boards so I'm not disclosing any new information that might have been given to me by contacts I still have at Monorails.
Last night was TRON-o-Rail's last run. Monorail Coral should be back out on the beamways within a month or so. She needs a nap and some TL&C in Shop.
Monorail_Red
Monorail_Red
Regards,
Monorail_Red
The views and opinions expressed on this post are mine and do not necessarily represent or reflect those of The Walt Disney Company.
Monorail_Red
Re: Bye-Bye to TRON-o-Rail
Aw, nuts! I'll have missed it by just over a month.Monorail_Red wrote:It has already been discussed on other boards so I'm not disclosing any new information that might have been given to me by contacts I still have at Monorails.
Monorail_Red
Going around World Showcase is like traveling in time and relative dimensions in space!
After a year and a half on the Epcot beam, only needing a month off is damn impressive.
I wonder what will happen the first time they put her onto Resorts for a day...
- Monorail_Red
A few months ago she was, in fact, on Resorts for a whole day or so AS the TRON-o-Rail! :D:Big Wallaby wrote:I wonder what will happen the first time they put her onto Resorts for a day...![]()
Regards,
Monorail_Red
Monorail_Red
We were there twice while it was running and managed to miss it both times. I was not a fan, but hubby would have liked to see it. Not enough to go looking while there, mind you, but enough to grumble about missing it.seeing_eye_child wrote:Aw, nuts! I'll have missed it by just over a month.
- Park: Canadas Top
- Department: Concert Hall!
- Position: Making Lights Move!
Why is resorts harder on the trains ? Is it the radius of the loop, or the fact that there are a lot more stops & door cycles during a day? Plus the longer days I assume?Big Wallaby wrote:After a year and a half on the Epcot beam, only needing a month off is damn impressive.
I was in Epcot the first day it was in operation. Good bye! I'll miss you.
Well, at least I can still see photos of it. Bye TRONorail, you had a good run.
RIP Bud Hurlbut.
You will be missed.
You will be missed.
Resorts isn't harder on the trains. It's that it will be operating from Cab 6 instead of Cab 1 for an extended period, most likely several days. When a train is put on Resorts, it spends at least one night out, if not two or three, to save it the trauma of going through the switches. Epcot is different because it has a smooth switch system.
Guys! Did you see that they're cutting back hours of monorail operations now-- closing down an hour after park close instead of running them during EMH???!!! I posted a link in the Newsroom.
Here's hoping all the trains will now get some TLC in shop. . .
...and I for one won't miss Tron-o-rail. Saw it last year, hated it! I was shocked by it in fact I remember asking Zazu "What have they done to my childhood memories!"
To me monorails should always be white with a colored stripe. Nothing else. No stickers, no promotional crud. Just perfect as they were.
~bru
~bru
Two things stand like stone:
Kindness in another’s trouble.
Courage in your own.
~Adam Lindsay Gordon
"...and only fireworks will light the sky at night
for all the world can see." ~Keane
