Directions to the nearest restroom
Grumpy
Post by Grumpy » Fri Feb 27, 2004 1:49 pm
Number one question; where is the restroom?
Guest is in the tomorrowland area comes up and asks where the restroom is, CM is standing right in front of it. Instead of just pointing out the restroom right behind him, he tells the guest to hop on the train, get off at the 4th exit, and the restroom will be right there. The guest hops on at the Tomorrowland station, gets off about 15-20 minutes later, sees the restroom, looks around, gets a dumbass look on his face, and proceeds to his destination.
Common guest trick, but I'm sure it doesn't happen everyday.
pixiedust
Post by pixiedust » Fri Feb 27, 2004 8:53 pm
Ah yes. The infamous "4th stop" trick. :) I don't even work INSIDE of the gates, and I know about it and think it's hilarious. We have brought that one up a few times in these forums.
