question about universal orlando
orangescamper
- Wide-eyed Newcomer
Hey everybody. I just have a question to ask since yall know alot about the parks. I will be going to Universal this month and my aunt gave me 2 tickets that she got from a friend and they are emp. comp tickets. Will I be able to use them?
Thank you.
Thank you.
Re: question about universal orlando
Check the back of the ticket and see if they have expired. Also look for any blackout dates. As long as they haven't expired and you don't go on a blackout date, you will be fine.
Call and find out if you need to have the employee with you at the time you use the tickets.
orangescamper
thanks for the help and replies.
I've never heard of comp tickets anywhere requiring the employee to be there, but it would definitely be a good idea to call just in case. At Disney the only time you don't need a CM to sign someone in is with the 2 comp tickets each CM gets a year.
orangescamper
thanks for the info.
Trust me on this: the employee comps do not require the team member to be with you. Some of you obviously think it is like the Disney maingate pass. It is not. The Universal team member comps do not require the team member to be with you.
Nor do they have blackout dates, unless this has changed in the year since I left Universal Hollywood. They do expire however, IIRC.
Universal Orlando employee comp tickets do have blackout dates. The blackout dates are printed on the back of the tickets. If you have tickets labelled as WinterBlast (which are tickets given out at Christmas), then they do NOT have black out dates. The other team member comp tickets do have blackout dates though.
