I need some help .. any CM recognize this nametag?
Walt Disney
Post by Walt Disney » Fri Dec 08, 2006 11:24 am
Any MK CM recognize this nametag? It has me stumped. Was it some sort of special event? Or is it one of the backstage divisions that make the magic happen? Any information is appreciated. Thanks, and have a magical day!
:D:
CBeilby
Re: I need some help .. any CM recognize this nametag?
Post by CBeilby » Fri Dec 08, 2006 3:32 pm
Either a WDW Millenium/Year 2000 nametag, or a WDW 20th Anniversary nametag.
Driver_dylan
Post by Driver_dylan » Fri Dec 08, 2006 8:57 pm
This was the name tags given out from 1999 to 2001 for the mellenium celebration. I wasn't a cast member back then, but on of my friends was and has a simmilar tag.
VISA. It's everywhere you want to be, and a lot of places you don't.
Post by Zazu » Fri Dec 08, 2006 9:39 pm
The oval tag is a standard issue tag for the Millennium Celebration, except that it's lacking a hometown. It's attached to a "Magic Kingdom Ride & Show" base.
This is the style of nametag used by Ride & Show Engineering at MK -- including the missing hometown. These are generally worn in a pocket protector rather than being pinned to a costume.
The reason for the base tag showing the department is twofold -- first, a pin-on nametag would be hazardous in their line of work, which includes getting up close and personal with operating attraction equipment. Second, it identifies them as someone who has a good reason to be messing about with attraction equipment. If I saw someone -- even someone with a current nametag, an appropriate costume, and a toolbelt -- working on or around my attraction *without* the R&S base, I'd e-stop the attraction and require them to leave, then call R&S Engineering to come inspect what these unauthorized folks might have done.
The hometown is missing because these folks are only exposed to guests as they are walking through park areas, and they don't particularly want to engage guests in conversations. If they're out there, it means that something important its broken.
Walt Disney
Post by Walt Disney » Fri Dec 08, 2006 11:37 pm
Thanks so much for the information. I just wasn't sure if it was a backstage department or not. I have several others like this in my Museum:
:D:
:D:
leftcoaster
Post by leftcoaster » Sat Dec 09, 2006 8:24 pm
Walt Disney wrote:Thanks so much for the information. I just wasn't sure if it was a backstage department or not. I have several others like this in my Museum:
Police Squad!:
Dutch Gunderson: Who are you and how did you get in here?
Det. Frank Drebin: I'm a locksmith. And, I'm a locksmith.
GMC
Post by GMC » Sat Dec 09, 2006 9:56 pm
I want a specialzed nametage plate that says "Slightly Disgruntled" and under my name instead of foreman "doesn't bite"
Gimme some soft serve!
hhsrat
Post by hhsrat » Sat Dec 09, 2006 11:48 pm
Zazu wrote:Second, it identifies them as someone who has a good reason to be messing about with attraction equipment. If I saw someone -- even someone with a current nametag, an appropriate costume, and a toolbelt -- working on or around my attraction *without* the R&S base, I'd e-stop the attraction and require them to leave, then call R&S Engineering to come inspect what these unauthorized folks might have done.
I think an exception to this can reasonably be made for engineering folks that you personally know. Unfortunately*, dealing with the Cat Canyon Maintenence team is a near-daily part of my job, and thus, I know them pretty well. If one of them showed up without their nametag, or with the wrong nametag, I'd still let them work on the attraction.
* They're nice people, but if I see them, it usually means that my attraction is in the midst of a problem that has the possibility to turn into a 101.
Post by Main Streeter » Sun Dec 10, 2006 3:22 am
GMC wrote:I want a specialzed nametage plate that says "Slightly Disgruntled"
Don't we all!! :cool:
LittleDollClaudia
Post by LittleDollClaudia » Sun Dec 10, 2006 3:37 am
Hell, if not, I vote for this t shirt.
Of course then I found a t shirt for Polar, in grey and everything. :giggles:
Click the linky for more!!
http://www.cafepress.com/fullmoonemp/124272
^^ Hey, that's me! ^^
