Where's the bathroom? You see that bush over there......
StupidGuestTricks Yahoo
Date: Wed Jul 17, 2002 5:59pm
Subject: Where's the bathroom? You see that bush over there......
Aloha
How about a story or two from WDW.....
This particular stupid guest trick is a real pet peeve of mine:
After telling a guest where the closest bathroom is to where they are
standing I get a stupid look and the question "Is that the closest?"
To which I answer "yes" and try really hard not to give them a stupid
look in return. One day I'm going to answer "No, that's not the
closest bathroom. It's actually all the way on the other side of the
park. And if you really want me to be honest, it's not even open."
One day.
Aloha
One day.
Re: Where's the bathroom? You see that bush over there......
[quote="StupidGuestTricks"]From: mk_tunnel_rat <]
I use this line a lot when I'm working as greeter at the Frontierland RR Station:
"Where's the restroom?"
"Under the bridge and behind that tree, sir."
"Huh? Behind the tree?!?"
"In the building behind the tree, sir. This is Frontierland, not Adventureland!"
ucf disneyfan
- Wide-eyed Newcomer
Some guests don't like to take the long hike to the bathrooms. Over the summer there was a guest who decided that his bathroom was at the base of the Frontierland RR, around the exit to Splash. When approached and asked why he did what he did he responded with "I didn't want to lose my spot in line". The man had left his two grandchildren in line while he relieved himself just outside the line.
xstechbabe
ucf disneyfan
TheManator
I have peed in a cup while on Pirates...I was just by myself, and nature called collect unexpectily..couldn't hold it, so I peed into one of those collectable drinking cups you buy for like $5.50
The Manator E
http://www.internetdj.com/themanatore
PirateJosh21
True Story....
Pirates was down for technical difficulties and I was located at turnstyles spieling to all guest that we would resume normal operations shortly. One woman kept screaming at me while I was assisting another gentleman.
CM: Just a moment and I'll be with you ma'am.
Guest: WHERE IS THE .........!
CM: *continuing with directions for the gentleman.
Guest: WHERE IS THE BATHROOM?
CM: Well you need to go back to mainstreet and go through the turnstyles, hop on the monorail to the TTC and then switch monorails to get to EPCOT. Then go insided the turnstyles there, Keeping in mind you need a park ticket to enter the park, and the bathrooms are inside to the right.
Guest: OKAY! THANKS!!!!!
CM: *runs after guest to tell her where the bathrooms really are*
Hey it was fun!
Hey it was fun!
I know that this doesn't have to do with WDW but it's a peeing story nonetheless. OK, so I was working on the Esplanade and some guest somehow got backstage and went. :-p He had to explain to me and another CM what he was doing back there, 2 security guards, the security lead, the Custodial Esplanade lead, and our manager! It was pretty funny. :-p
"I have a stupid question for you."
"Can I have a map?"
"Where is the restroom?"
"Do you work here?"
"Can I have a map?"
"Do you work here?"
