The hardest question known to man:...How many in your Party?
Re: The hardest question known to man:...How many in your Party?
That is a word that none of our offices use. Our main goal in my area is to keep the area running. If we start to run out of food we call back. The only things we hear about are problems with registers and lack of crew showing up. Once in a blue moon do we hear about DCA. They are on a different channel.
I give up. ;)turkeyham wrote:Once in a blue moon do we hear about DCA. They are on a different channel.
She isn't talking about on the radio, I sorta doubt they use that acronym on the radio. She's talking about how CMs refer to the attraction when talking about it. It's Disneyese, like CM for Cast Member, ODV for Outdoor Vending, etc.turkeyham wrote:That is a word that none of our offices use. Our main goal in my area is to keep the area running. If we start to run out of food we call back. The only things we hear about are problems with registers and lack of crew showing up. Once in a blue moon do we hear about DCA. They are on a different channel.
Gotcha!Main Streeter wrote:Yes, Toy Story Mania. Was keying to an ODV CM.
Close, ODV could be Ourdoor Vending and ODV on DCA is Outdoor Ventures.
We have 2 different radio systems. On our radios out here at Dineyland we have several connections. When you join, you push a button and you are connected into the Disneyland side. When we hear about certain areas which are having down time (101) or (904 alarms) there will be a long tone and they say "attention all areas"... That's when we do hear about info from both parks. Usually control says this.
lady ulrike
They're not talking about radio calls or calls on the radio. None of this has to do with a radio, we're just talking about general CMs talking in the breakroom or wherever about things. For example, I never say Disney's California Adventure, I say DCA, it's a small world is just world, and so on. That's what is being talked about here, it has nothing to do with what's said on the radio.turkeyham wrote:Close, ODV could be Ourdoor Vending and ODV on DCA is Outdoor Ventures.
Disneyguy85
If you do make it over to DCA, have fun, but be prepared to see a lot of construction walls.turkeyham wrote:We don't venture much over to DCA. I have been on that ride 3 times. Maybe I should go on it on Friday.
Whenever I see TSM, I automatically think "Terminate and Stay Mania"
hehehehehhe
hehehehehhe
I'm thankful I'm not there. ;)GRUMPY PIRATE wrote:Whenever I see TSM
And chatrooms. :D:turkeyham wrote:On our radios out here at Dineyland we have several connections.
