I would have said the ear. :twisted:DisneyMom wrote:In the side of the offending SG? ;)
an sg + a stroller =
Re: an sg + a stroller =
Naw, wouldn't do any damage there. A Deliberate SG (as opposed to the occasional "senior moment") has their "brains" (and I use that term very broadly as they are not brains as I recognize them) protected under thick fat padding in the posterior region. So a fork in the ear will only increase the whistle of air flowing through. But a kick in the a$$ has some chance of causing shock waves through the fat to the scene of all SG thinking processes.hobie16 wrote:I would have said the ear. :twisted:
I'd look at it as applying a mental floss probe.Randy B wrote:Naw, wouldn't do any damage there. A Deliberate SG (as opposed to the occasional "senior moment") has their "brains" (and I use that term very broadly as they are not brains as I recognize them) protected under thick fat padding in the posterior region. So a fork in the ear will only increase the whistle of air flowing through. But a kick in the a$$ has some chance of causing shock waves through the fat to the scene of all SG thinking processes.
But, an increase in the whistling of air flowing through the head might give you advance warning, allowing you time to brainstorm better ways of dealing with said SG.Randy B wrote:Naw, wouldn't do any damage there. A Deliberate SG (as opposed to the occasional "senior moment") has their "brains" (and I use that term very broadly as they are not brains as I recognize them) protected under thick fat padding in the posterior region. So a fork in the ear will only increase the whistle of air flowing through. But a kick in the a$$ has some chance of causing shock waves through the fat to the scene of all SG thinking processes.
Light travels faster than sound. Perhaps that is why people appear bright until they open their mouth.
Come to think of it, if said SG had large, floppy ears and a slight restriction, the wind whistling through might make a "bronks cheer" noise instead of a whistle. Maybe thats what I have heard in the HM stretching room or in various lines from time to time. An SG cheer.dancinghomer wrote:But, an increase in the whistling of air flowing through the head might give you advance warning, allowing you time to brainstorm better ways of dealing with said SG.
Jeebus people. Work inspires such violent thoughts in you people.
Legend: Alligators dwell in the sewers beneath Disneyland.
Truth: There are no sewers below Disneyland, and therefore no alligators in them. The secret tunnels are infested with mutant rats, however.
<3 disneylies.com
smart1hermione wrote:i love that logic.
"what is the correct placement of an oyster fork?"
Umm, in the butt, bob.
(My omage to the newlywed game!)
I remember that one from one of those blooper shows. Its even funnier when you know what the question was. :D: :twisted:GRUMPY PIRATE wrote:Umm, in the butt, bob.
One of the dangers of piercing a SG's head with any sharp object is that the vacuum inside the head would cause the SG's head to explode, possibly injuring the CM with said sharp object.
Naw. A vacuum would cause the head to implode and suck the CM into the vast empty void. Maybe we have inadvertanly discovered the cause of SGs. Their heads contain a small black hole that sucks every thought into another dimension!felinefan wrote:One of the dangers of piercing a SG's head with any sharp object is that the vacuum inside the head would cause the SG's head to explode, possibly injuring the CM with said sharp object.![]()
