Character Smilies Reorganized
Re: Character Smilies Reorganized
It will power the voice services for about 4 hours, reports of up to 5 hours have been seen. I haven't tested to see if the data port stays up.
The current documentation says 8 hours -- 7 immediately, with one hour held in emergency reserve (you can activate it with a button press on the backup unit).ktulu wrote:It will power the voice services for about 4 hours, reports of up to 5 hours have been seen. I haven't tested to see if the data port stays up.
To show how out of the loop I've been on this, when hobie first asked if it came with UPS, I thought, "That's an odd question. Why would anything need to be delivered?"
Are you on multimode or single mode fiber? Do the active electronics use LED or laser for the light source?BRWombat wrote:To show how out of the loop I've been on this, when hobie first asked if it came with UPS, I thought, "That's an odd question. Why would anything need to be delivered?"
Yes.hobie16 wrote:Are you on multimode or single mode fiber? Do the active electronics use LED or laser for the light source?
Don't feel bad, Wombat.....
Whenever talk of computers comes up, all I can hear in my mind is that sound the teacher used to make when she was speaking on the old Charlie Brown cartoons.....
Mwaaaaaa mwaaa mwaaaaa.......
Mwaaa mwaaa mwaaa mwaaa!
I mwaaaaa to the mwaaaaa mwaaaaa which meant mwaaaaa and mwaaaaa with a mwaaaaa. The mwaaaaa also developed a mwaaaaa mwaaaaa mwaaaaa but was limited to mwaaaaa.
Oh, to partially answer your question, it is single mode fiber.
Have you moved to DWDM yet?ktulu wrote:Oh, to partially answer your question, it is single mode fiber.
On some level, yes ;)hobie16 wrote:Have you moved to DWDM yet?
Hey - if you guys are gonna post, at least you could do it in English. :p:
:D: :D: :D:
:D: :D: :D:
