mom had the turkey dinner
I got: ton of lettuce, my honey mustard dressing, lots of bacon, roasty beef, cheese, cucumbers, tomato, and a bit of cilantro. DESSERT WAS A HOT FUDGE SUNDAE.
Happy Thanksgiving 2008
Re: Happy Thanksgiving 2008
Belated Happy Thanksgiving to everyone. I wanted to post early but I've been busier than a turkey with its head cut off (or is that a chicken with its legs cut off ???)
Of course my Lions got their asses handed to them on a platter. (I knew I should have watched a movie with the G-kids)
I'm going to get an early start, MERRY CHRISTMAS.
We wants the recipes!LittleDollClaudia wrote:Yay for turkey!
Mmm, I can't wait to start making deviled eggs and bacon wrapped breadsticks for munchies until the turkey's done.
DIET OR REGULAR? :hysteria:mechurchlady wrote: DESSERT WAS A HOT FUDGE SUNDAE.
I'll teach you to be more specific!Ms. Matterhorn wrote:We wants the recipes!
Roast Duck a la Zazu
Send Donald out for a couple of days, then buy a duck (preferably dead).
Skin the duck, removing as much fat as possible. Cut off the ends of the wings, as there's not enough there to be worth cooking. Wash clean and pat dry (or the marinade won't stick). Coat with Marinade (below). Place in refrigerator at least overnight. Stuff (below) and roast at 325 degrees for about 90 minutes (depending on your oven). Let rest for ten minutes, then carve and serve.
Marinade
Mix equal parts honey and ground cumin. You may also add to taste such items as ground cloves, cinnamon, ground or finely chopped rosemary or sage, but probably not all of them. Do not add salt! Use the least honey necessary to make the mix all work -- it's a binder, not a sweetener.
Stuffing
To each his own, and I own a different formula each year. This year it was:
half a large onion
several large carrots
half a butternut squash
small handful of pecans
one spicy sausage (I used chorizo)
Chop all coarsely and set aside. Use the squash for a guide, you should have the same volume of the last four items and twice as much onion.
Prepare some mushrooms. This year I used dried porcini mushrooms, which need to be reconstituted by boiling in liquid for five minutes. Drain, chop, and set with other items above.
While you can boil the mushrooms in sherry, I used one box of chicken broth. However you do the mushrooms, heat the box of chicken broth anyway.
Put the onions in a large pot with twice as much butter as you think they deserve. Oil isn't a good substitute here, as you want the butter for the cornbread. Sweat the onions, but stop before they start to brown.
Add the other veggies and nuts except the mushrooms, and enough stock to cover. Simmer until the carrots are half done, seasoning to taste. The same mix used for the marinade is a good start. This time you may add salt if you like, but go light.
Remove from the heat, add the mushrooms and cornbread, mix. Add more hot stock slowly until the mix starts to make balls that stick together.
Stuff it!
Serves two with leftovers, four if there are lots of side dishes.
I am never going to live that down, am I?Ms. Matterhorn wrote:DIET OR REGULAR? :hysteria:
Let me check my notes and see if everything is plugged in properly.CBeilby wrote:I am never going to live that down, am I?
*Kicks machine*
The answer is that you can regularly have a diet but cannot diet regularly.
Hey dont blame me, blame the computer technician who worked on the machine. :D:
My second youngest sister took over this year and made dinner. If you entered the kitchen, you would get kicked out or suddenly become her cooking slave. I wondered into the kitchen to get a glass of water. I ended up peeling 14 large potatoes and toasting 1 loaf of bread in the toaster. She made some scary stuffing, I did not eat because almost all the gross stuff from the turkey went into it.
But dinner was good. After 3 servings of food, I had a nice slice of apple pie and whipped cream. Add 3 bottles of champaine and the room starts to spin.
The answer is most definitely.....CBeilby wrote:I am never going to live that down, am I?
No!!!
Go Wombat and VM!
Go Wombat and VM!
*highfives Ms. Matterhorn :hysteria: :D:Ms. Matterhorn wrote:DIET OR REGULAR? :hysteria:
Go Wombat and VM!
Go Wombat and VM!
