agree with that!!!felinefan wrote:I hate sour candy unless it's lemondrops. To me, sour candy is an oxymoron.
(and if you get the lemon drops from Vermont country store, they are sweet!!!)
It must be caused by all the maple syrup in the ground water.GRUMPY PIRATE wrote:agree with that!!!
Ummm... isn't that where the pitfall is at?ktulu wrote:Out the door and to the left.
No, no, no. The pitfall is out the door, to the right, over the hill, around the outhouse, through the tunnel, across the pond, first star to the left, down the spiral staircase, up the tree, down the zipline, over the railroad tracks and a little to the left. You can't miss it.Shorty82 wrote:Ummm... isn't that where the pitfall is at?
Whoops, I probably shouldn't have said that out loud.
Are you saying I should have stayed a bus driver?hobie16 wrote:If you place the purples in a safe place, they will mutate into gold.
It would only work if your pants were made of a chalky substance.Big Wallaby wrote:Are you saying I should have stayed a bus driver?
I'm sure that if one goes long enough between laundering, that will happen.hobie16 wrote:It would only work if your pants were made of a chalky substance.
It could if they don't fall apart first.Goofyernmost wrote:I'm sure that if one goes long enough between laundering, that will happen.![]()
