albino_pygmy
- Park: Magic Kingdom
- Department: Jungle Navigation Co
- Position: Skipper
by albino_pygmy » Wed May 14, 2008 4:39 pm
What about dealing with an infestation of these pests:
The ever frightening and largely multiplying Tackius Touristosus
Skipper's General Warning!
Reading of this signature might result in the following:
Lung Cancer, Heart Disease, Nausea, Heartburn, Indigestion,
Upset Stomach, Diarrhea, and may Complicate Pregnancy.
Consult a physician if read thoroughly.
by hobie16 » Wed May 14, 2008 9:32 pm
albino_pygmy wrote:What about dealing with an infestation of these pests:
I see packs of them every time I go into Lahaina. The best ones are the couples that dress in the same pattern aloha shirts and dresses from Hilo Hatties. The colors burn my retinas. Arrrggghhhhhhh!!!
Cranbiz
by Cranbiz » Wed May 14, 2008 10:58 pm
The bugs are here!
Needed a trip to FIW to add more washer fluid to the bus today to try to wash off the carcuses.
Now, can anyone tell me why FIW won't fill the washer fluid when they service the bus for the night?
No longer the Wearer of Purple Pants
No longer a General in the Bolivian Army!
"The views and opinions expressed on this post are mine and do not necessarily represent or reflect those of The Walt Disney Company."
Randy B
- In our Memory
by Randy B » Thu May 15, 2008 2:29 am
Cranbiz wrote:The bugs are here!
Because if they fill it up you will just go and waste it all.
If they leave it empty you will be forced to get by with the few spits they left you, or use the less expensive water (bottled of course) that really does no good. On the other hand if you are unable to see out and run the bus into a canal the long soak until it can be towed out may loosen the bugs enough that a quick rinse to remove the mud would mostly take the bugs off too. So remember, when the lovebugs have fully smeared your bus, a not-so-quick dip in a nearby canal could be the solution. When the bus maint super asks about the "dip" you can explain that you are simply following apparent proper procedure as this is the most useable alternative to using all that expensive washer fluid (you know how hard it is to squeeze fluid from a metal washer). :D:
by hobie16 » Thu May 15, 2008 12:38 pm
Randy B wrote:..a not-so-quick dip in a nearby canal could be the solution.
Find a canal that's had some industrial waste dumped in it. That'll speed up the bug removal process but may be kinda hard on the paint.
by GRUMPY PIRATE » Thu May 15, 2008 2:41 pm
hobie16 wrote:Find a canal that's had some industrial waste dumped in it. That'll speed up the bug removal process but may be kinda hard on the paint.
And the passengers!
by kurtisnelson » Thu May 15, 2008 3:51 pm
That picture makes me think of Family Auto Mart for some reason. Luckily I have not seen them in a long time.
by BRWombat » Thu May 15, 2008 4:51 pm
hobie16 wrote:I see packs of them every time I go into Lahaina. The best ones are the couples that dress in the same pattern aloha shirts and dresses from Hilo Hatties. The colors burn my retinas. Arrrggghhhhhhh!!!
This is waaaay OT, but hobie, just out of curiosity, how do you recommend a tourist to Hawaii act -- beyond common courtesy, common sense, and all those other rare commodities? I mean, if I visit Hawaii there's no way I could ever look or talk like an islander -- more like sunburned ice cream guy from Lilo & Stitch -- so I know I'd be pegged as a tourist. What's the best way to be a
non-annoying tourist?
by GRUMPY PIRATE » Thu May 15, 2008 5:37 pm
BRWombat wrote:This is waaaay OT, but hobie, just out of curiosity, how do you recommend a tourist to Hawaii act -- beyond common courtesy, common sense, and all those other rare commodities? I mean, if I visit Hawaii there's no way I could ever look or talk like an islander -- more like sunburned ice cream guy from Lilo & Stitch -- so I know I'd be pegged as a tourist. What's the best way to be a non-annoying tourist?
Ummm, spend a LOT of money??
hehehehehe
albino_pygmy
- Position: Skipper
by albino_pygmy » Thu May 15, 2008 6:17 pm
kurtisnelson wrote:That picture makes me think of Family Auto Mart for some reason. Luckily I have not seen them in a long time.
Weeeeeeeeeeeeeeeeeeeeeeeeeeeeeee're fixin to learn ya! (*inaudible redneck lyrics because I couldn't figure out what else they were singing*)
