Overheard in the kingdom
EpcotFan
Re: Overheard in the kingdom
Post by EpcotFan » Tue Feb 15, 2011 1:21 pm
hobie16 wrote:It's an ethnic dish usually served with Tree Frog beer.
How about with a Dead Frog instead?
http://www.deadfrogbrewery.com/
I'm sure this would go quite well with corn on the cob. :D:
turkeyham
Post by turkeyham » Tue Feb 15, 2011 1:58 pm
Yes, SG was pointing at BTRR and started to get in line for the attraction.
Next time, I will keep a small notebook and watch the SG and their comments.
The Gold Rusher is not a roller coaster at Disneyland, that is the yellow coaster at Magic Mountain. That is the one with all the gum stuck to the right side of the pole. :eek:
CptnSkippy
Department: F&B
Post by CptnSkippy » Thu Feb 17, 2011 5:24 am
Zazu wrote:Naw, we're just so glad that you're *using* a restroom instead of the landscaping....
Ugh - I recall when i was younger seeing a family letting their little boy pee off the side of the TTC monorail station. :duh:
Chaka Peachfuzz
Post by Chaka Peachfuzz » Thu Feb 17, 2011 8:24 am
CptnSkippy wrote:Ugh - I recall when i was younger seeing a family letting their little boy pee off the side of the TTC monorail station. :duh:
That is just WRONG!!! :eek:
Post by Zazu » Thu Feb 17, 2011 10:22 pm
That's not so bad. I once had a young lad pee off the platform of the Frontierland RR Station... right above the FastPass queue to Splash Mountain!
Mountain 8 was more than a little confused when I called to tell them they had a Voban situation that needed attention.
At least the kid's dad acted surprised when he noticed, it's not like he had suggested it.
lilogirl
Post by lilogirl » Fri Feb 18, 2011 5:01 pm
Zazu wrote:That's not so bad. I once had a young lad pee off the platform of the Frontierland RR Station... right above the FastPass queue to Splash Mountain!
eeeeewwwwwwwwww ick eeeeew! I would have made "Dad" clean it up.
Post by Big Wallaby » Sat Feb 19, 2011 4:48 am
I am thinking that may have taken more than Voban. I am hoping the queue was relatively empty that day... but I am not so naive.
EeyoresButterfly
Post by EeyoresButterfly » Mon Feb 21, 2011 5:03 pm
turkeyham wrote:Today was the best day for SG in the rain!
SG: Does Disneyland still launch the fireworks in the heavy rain? :confused:
CM: No, because when the fireworks are set off, they have a fuse lit with a flame. :mad:
How lame can these people get?
Actually, we do set them off in heavy rain, unfortunately it results in the smoke hovering so by the end of the show you can't see much more than random flashes of light. At the most, they tyipcally delay the show, and even then for lightning. At least, that was how it was when I worked there. What I was told by pyro crew is that once they are loaded, they have to be set off. So Disney's choice is to set them off with guests there, or after the guests leave. Hmmm, I wonder which one they will choose? In three CPs (each of approximately 8 months of length) I have never seen a show cancelled. I think it may have been delayed once or twice, but never cancelled.
So that is actually a very reasonable question and that CM is wrong, unless they have changed the policy since I have been down there.
Petite and Proud!
Post by Goofyernmost » Mon Feb 21, 2011 6:45 pm
EeyoresButterfly wrote:Actually, we do set them off in heavy rain, unfortunately it results in the smoke hovering so by the end of the show you can't see much more than random flashes of light. At the most, they tyipcally delay the show, and even then for lightning. At least, that was how it was when I worked there. What I was told by pyro crew is that once they are loaded, they have to be set off. So Disney's choice is to set them off with guests there, or after the guests leave. Hmmm, I wonder which one they will choose? In three CPs (each of approximately 8 months of length) I have never seen a show cancelled. I think it may have been delayed once or twice, but never cancelled.
I don't know what the policy is but I do know that it has been a long time since actual flame lighting fuse had been used anywhere. It's all electronic now so unless they haven't taken the precautions necessary to not have the wires short out...I'd say it doesn't matter if it's raining or not. I, however, would not be standing out in the rain to watch a bunch of loud flashes of light. But that's just me.
Post by Big Wallaby » Wed Feb 23, 2011 3:07 am
EeyoresButterfly wrote:I think it may have been delayed once or twice, but never cancelled.
I have seen Wishes canceled once, and that was when a hurricane was blowing by (note: I did not say through). It was very high winds, and they waited until we had even put the Monorails away. Then, the Castle shells started going off, in real time, but with no music playing. The large shells behind the park were not being launched. It was eerie.
