OK here goes:Zazu wrote:Good to hear that Disney policy has gotten more rational on CPR and AED use. News of these changes hasn't yet reached me through official channels, but then not all that much does.
Haven't seen a notice about CPR classes since 2001.
Latest American Red Cross training emphasizes 3 sets of 20 compressions then a breath. Repeat. Mouth to mouth has not been eliminated completely yet...at WDW, we do breathing. All of us have mouth breathing equipment or access in the AED device.
Before any CM starts CPR.
*Secure the scene.
*Call 911 -- ask for Reedy Creek.
*If a second person is there, direct them to nearest AED location. Yes, this can include a guest, but try to make it a CM.
*Let Reedy Creek know what location you sent them to and exactly where you are with the patient.
*The 911 operator will help you evaluate patient before you start beating on patient's chest.
BTW, a "first responder" should be at your location way before you actually get to start CPR.
If you are not a first responder, do not touch or move guest unless explicitly instructed to by Reedy Creek or patient is in danger (AKA scene is not secure). Again, this should never happen since a 'first responder' should be on scene within a minute or two.
Do not bother to get CPR creds just for becoming a CM. If you need it, we will train you. Disney has a way of doing everything and CPR is one of them. Yes, we go above American Red Cross guidelines.
Any CM can pull an AED. Any CM can attach the AED leads to guest following the AED module's instructions. You may not attempt to shock guest unless the module TELLS you to...not only will it not deploy but it will record the attempt and start over with instructions.
MAPO
