Just back...whopper of a SGT
Re: Just back...whopper of a SGT
Post by hobie16 » Thu Jul 08, 2010 8:47 pm
jldrn1 wrote:Yep, this is turning into board x.
Oh pulleeezzeeee!
Post by Main Streeter » Fri Jul 09, 2010 1:20 am
Not even! :(
Post by GRUMPY PIRATE » Fri Jul 09, 2010 12:11 pm
As bill clinton would say "Close, but no cigar!" :rolleyes:
christina54
Post by christina54 » Mon Jul 12, 2010 11:55 am
people can be so thoughtless and rude. my daughter uses a wheelchair because she has a heart condition and the constant walking in the heat isn't good. we don't use the chair to gain immediate access to rides or even take it w/us. we park it w/strollers. anyway, i brought a letter from her cardiologist detailing her medical condition, just in case we'd have to take her to a doctor in Florida. according to guest services they cannot ask for proof of disability. something about discrimination. i personally agree that there should be something to show when you are seeking special privilege. i've seen many kids rent a chair and use it to gain access to rides quicker. adults too. the sense of entitlement is astounding at times with some people.
Cheshire Figment
Post by Cheshire Figment » Tue Jul 13, 2010 10:10 pm
The lines for almost all attractions at WDW are "mainstreamed". This means that the queue is set up to allow wheelchairs and/or ECVs to go through the line just as a person without a mobility problem. As it was built prior to the ADA, the Magic Kingdom is most likely to have non-mainstreamed lines. Some attractions, such as Splash Mountain and Haunted Mansion you will go part way through the regular queue and then be diverted. Other attractions, such as Big Thunder Mountain or SpaceShip Earth you will initially be directed to an accessible entrance.
All the theaters are set up with seats (usually in the back row) removed so a wheelchair or ECV can pull into a space and there will be regular seating on either side of the space for the others in the party.
Where there are quantity limits on space, or other limitation involving accessibility, you may have to wait longer to see a show or ride an attraction than people without disabilities.
The normal (and official) response of Guest Relations to people with mobility and/or stamina issues is to recommend rental of a wheelchair or ECV. The Guest Assistance Card (GAC) is intended for "invisible" disabilities not related to mobility or stamina. A wheelchair or ECV is sufficient to notify Cast Members of special assistance normally needed. However, if a person has other issues, such as auditory or visual, they would probably also need a GAC.
Note that a GAC is not intended to allow bypassing of lines, and it so states on the card itself. The only people who will get the special Front Of The Line GAC are where a terminal or medically fragile child is traveling on a trip from Make A Wish or similar foundation.
GaTechGal
Post by GaTechGal » Wed Jul 14, 2010 11:57 am
So do you think that the Magic Kingdom will become more accessible with the new Fantasyland renovation?
Post by ktulu » Wed Jul 14, 2010 2:42 pm
GaTechGal wrote:So do you think that the Magic Kingdom will become more accessible with the new Fantasyland renovation?
Maybe when it is done, during construction look for restricted access to certain areas, but the work walls will be the obvious hint :D: *
* This sarcastic post brought to you by BEER!
:beer: :biggulp: :cheers:
Post by Lasolimu » Wed Jul 14, 2010 3:13 pm
ktulu wrote:* This sarcastic post brought to you by BEER!
When isn't one of your posts brought to us by beer? :confused:
:p:
Post by hobie16 » Wed Jul 14, 2010 4:12 pm
Lasolimu wrote:When isn't one of your posts brought to us by beer? :confused:
:p:
I think it's because of beer.
Post by darph nader » Wed Jul 14, 2010 4:25 pm
hobie16 wrote:I think it's because of beer.
Aaand? What's your point?
